Mach Discussion => General Mach Discussion => Topic started by: borrisl on January 31, 2006, 08:29:25 PM
After installing 1.90, non of my toolpaths display in the graphics box. The green, toolpath trace shows up during machining, but nothing apears from regen toolpath. Anything I am doing wrong?
Hi:
Hmm, check the toolpath config. Did the coloutrs get set to black or something?
Nope.
Is the file a series of G81'sd only? They may not display much other than red lines to get there. Load the roadrunner, does it display??
Art
No display with road runner. It's naked!!!!
Now I have 1.84 with no toolpath display. Wonder if I should employ the uninstall, clean, and reinstall option?
Try to double click on the graphic screen. This will tell it to redraw...
I don't know what the problem was, but I uninstalled, deleted the Mach3 folder, deleted anything I could find in the registry, and then reinstalled. Now, life is grand.
Black hole ??
John s.
