Mach Discussion => General Mach Discussion => Topic started by: thespindoctor on September 21, 2011, 02:13:02 PM
While working mach crashed and I had to reboot the computer. After this mach loader did not recognize by .set file even though it is there in the Mach3 directory. Also, when I open LazyCam on another computer, it recognizes and loads the current file in the editor but on the computer that crashed, LazyCam cannot find an active Mach3 nor a program to load. This problem has been present ever since I started using it.
Also, I am trying to change a Y value in a G57 offset but I can only read it from CBasic and not able using setOEMDRO(831) to modify it
Post your xml file.
