Mach Discussion => General Mach Discussion => Topic started by: BR549 on September 19, 2011, 01:11:48 PM
Now bear with me on this one(;-) . IS there a way to lock a computer into a SET processing speed( for the lack of a better term). It seems problems arise between computers of different processing speeds with the MachCB macro code.
I know on commercial controllers that are ALL of the same make use the same boards, it is not a problem as the processing speeds are all the same.
IF mach could LOCK IN a certain speed perhaps that would help with creating UNIVERSAL CB code???
I also may not be making any sense trying to describe it(;-)
Just a thought,(;-)
Terry I think its more than just processing speed, I have run Mach on 400Meg CPUs to 1Gig that I use on my machines now to 7750 Dual Cores and even quad cores and not seen a problem with macros. That would lead me to think there is something else that is at play here and as I have never seen it I am afraid I wouldnt know where to start looking.
HOOD surely you have seen it or you would not have to load up the CB code with While Ismoving() Wend statements after almost everyline of code(;-).
I have on old MB 1.2ghz that will run CB in native format without problems AND rarely does it require a While Ismoving() to slow it down. Another MB 3.0 ghz will choke mach and skip all over the code without a ton of wait states added in.
Just looking for a common denominator, (;-) TP
I see what you are talking about now but with me not being a programmer I just thought it would be good practice to write code to wait if you were wanting it to, looks like its not?
I have also had problems what seam to be related to CPU speed in VB code. ( works on one machine and screws up on another) Have to tried adding a sleep command in your while loop?
I have an 800mhz that will skip without isMoving() statements. Also have a 2.8ghz that does the same thing. The problem is that CB code executes faster than G-Code. I don't think slowing down the processor so CB executes at the same speed, even if it were possible, is a good solution. Never had a problem with isMoving statements, other than it makes the code look a bit messy. I've done tests where I executed a specific G-Code routine using just CB with isMoving Statements and just straight G-Code. Execution time was the same...Or so close it wasn't perceptible.
A test we did long while back took a 100 line section of Gcode and ran it 2 ways.
1 as straight Gcode.
2 as Macro code with all the While Ismoving() to maintain control.
There was a NOTICABLE difference in the 2 programs . The Gcode only program ran a smooth as silk as Mach loaded the buffer full . The Macro ?? NOT so smooth as if Mach was running it ONE line at a time and then wait and run another line of code.
I have a POLAR probing array that will gather 9,801 points per session as a Gcode program it runs smooth as silk running as fast as you dare to try. As a macro it is PAINFULL to watch it run.
May be time to try it again(;-), (;-) TP
I try it every day. I've been running code in macros for years.
"NOT so smooth as if Mach was running it ONE line at a time and then wait and run another line of code."
I get this issue when running straight G-Code on small segmented arcs such as a lead in or a slot with a long long straight segment then a small arc. Mach will hesitate at the start and end points of the small arc as if it's in exact stop mode. If I make the arcs larger, it's smooth as silk.
