Mach Discussion => General Mach Discussion => Topic started by: BR549 on August 30, 2011, 09:22:50 PM
For the ones using Scam with Mach3 it is now possible for Scam to generate Barcodes from the report generator. This is really handy for those that use a Barcode scanner to load Gcode Programs into Mach3.
I use it to generate a JOB report from Scam to go in the Job package. Then at CUT time the Guys can pull the report out and scan in the correct Gcode Program into MACH3 . Just makes it a little easier and lessens the chance of error as some cuts look a LOT alike.
Just a thought, (;-)TP
