Mach Discussion => General Mach Discussion => Topic started by: Briantaylor55 on August 02, 2011, 04:47:13 PM
i purchased a small cnc with mach 3 several months ago and got it all working OK.
Now after a long break I have connected to a new computer, but cannot get the Mach 3 to respond, either with the CNC connected or without. I cannot even perform a simple jog.
Obviously Ive overlooked some very simple setting or switch, but I am tearing out my hair just to get started
HELP PLEASE
If the RESET button is flashing click it.
Its not that.
Also I notice on the diagnostics screen, port 1 Pins current state, none of the boxes are highlighted green
Rich,
sorry I forgot to say, thanks for the tip.
Did you run the driver test as that installs the driver? Do you have the port enabled in Mach along with an address?
I am assuming that you are using your former xlm file, so if it worked before...should work again if the above was done.
Hi Rich,
Lost me with this lot. Its a while since I downloaded it, so I think it may be best to uninstall and start again from scratch.
Hi Rich,
Decided to run the driver again just before I uninstalled.
IT WORKED !!! I'm up and running
Thanks for the help, Its saved me from tearing out the last of my hair.
We'll give ya some time and you'll be bald like the rest of us ........ :D
Glad it's working,
