Mach Discussion => General Mach Discussion => Topic started by: tiofilo123 on July 14, 2011, 11:50:47 PM
hello all
just installed my xobox 360, read most of the posts and got it installed, Its insalled in mach 3 because i can see it in the plug ins, i checked the green check mark to activate it. for some reason none of my controls work. any suggestion
forgot to mention, when i plug the 360 into the usb port the green light does turn on in the center of the control
Did you configure the settings for the controller to what buttons do what in mach3?
If your PC has not internet connection, did you download the controller driver?
Check out the setup guide, if you have not already.
