Mach Discussion => General Mach Discussion => Topic started by: generlsocial on July 07, 2011, 04:01:01 PM
Hello Everyone,
I just got at DC-03 DigiSpeed GX V3 to control my chinese C02 laser. I want to use Mach 3 or EMC2.
Has anybody gotten it running? What is the wiring diagram? Which pins do you use on the parallel port?
Here's a picture of it: http://mambohead.com/2011/07/laser-controller-design/
I will get through it eventually but if someone already has it working perhaps they could share what they did?
Thanks in advance!
Darcy
Darcy,
This is a pretty old thread but it is straightforward enough to connect the analog 0-5Volts to the laser PSU and it is again straightforward to setup the spindle control within Mach to output the PWM (do a search for PWM and you will find the details). This works just fine for vector cutting but if you decide to do raster work using the Impact/Laser Engraver plugin it all goes pear shaped.
There are more details in these threads (if you have a bit of time to spare :D );
http://www.machsupport.com/forum/index.php/topic,16446.0.html
http://www.machsupport.com/forum/index.php/topic,12444.0.html
Hope this helps,
generlsocial - as Tweakie said, you ressurected a pretty old thread here so I've split it out and given you your own. Welcome BTW.
