Mach Discussion => General Mach Discussion => Topic started by: inivator on July 03, 2011, 05:41:50 PM
I'm using stepper motors, set in a 1/2 step mode. What should the steps per rev be set at. I have mine set at 1000.
400 would be normal steps per rev with half stepping. Unless that is your steppers are the more uncommon 0.9 degree ones in which case it would be 800.
:)Thanks for the help.
