Mach Discussion => General Mach Discussion => Topic started by: Jackal on June 03, 2011, 10:01:50 AM
Where can you get just the enclosure?
Here is the type:
http://www.google.com/imgres?imgurl=http://www.dubuque-forsale.com/OLD-ADS-FROM-PREVIOUS-YEARS/2007/November/Honeywell-limit-switch-BZE6-2RQ8-04M8415-picture.jpg&imgrefurl=http://www.dubuque-forsale.com/OLD-ADS-FROM-PREVIOUS-YEARS/2007/November/Honeywell-limit-switch-BZE6-2RQ8-04M8415.php&h=300&w=400&sz=12&tbnid=cKjYUD6uAASXUM:&tbnh=93&tbnw=124&prev=/search%3Fq%3Dhoneywell%2Blimit%2Bswitch%2Bpictures%26tbm%3Disch%26tbo%3Du&zoom=1&q=honeywell+limit+switch+pictures&hl=en&usg=__ZvyJwV1LjuMqO6BIkQELoAFT8MQ=&sa=X&ei=IOfoTcGOJI2Etgea2vzAAQ&ved=0CC8Q9QEwAw (http://www.google.com/imgres?imgurl=http://www.dubuque-forsale.com/OLD-ADS-FROM-PREVIOUS-YEARS/2007/November/Honeywell-limit-switch-BZE6-2RQ8-04M8415-picture.jpg&imgrefurl=http://www.dubuque-forsale.com/OLD-ADS-FROM-PREVIOUS-YEARS/2007/November/Honeywell-limit-switch-BZE6-2RQ8-04M8415.php&h=300&w=400&sz=12&tbnid=cKjYUD6uAASXUM:&tbnh=93&tbnw=124&prev=/search%3Fq%3Dhoneywell%2Blimit%2Bswitch%2Bpictures%26tbm%3Disch%26tbo%3Du&zoom=1&q=honeywell+limit+switch+pictures&hl=en&usg=__ZvyJwV1LjuMqO6BIkQELoAFT8MQ=&sa=X&ei=IOfoTcGOJI2Etgea2vzAAQ&ved=0CC8Q9QEwAw)
Would it be ok just to make up a couple of aluminum boxes, then thread them at the plunger, with an o-ring installed?
JAckal
If you EBay "Enclosed Limit Switch" there are many different types of complete plunger switches at low prices, maybe there is a suitable type there that you could use to replace your existing switches.
Thanks for the reply, Tweakie.
I just wanted to use these switches because they were new. My machine has the old proximity switches and these wont fit in the same box.
JAckal
