Mach Discussion => General Mach Discussion => Topic started by: davy182 on May 03, 2011, 01:24:09 PM
Just checking to see how hard it would be to reuse a wincnc controller for mach3. I would appreciate any input.
David
Afraid I have no idea how WinCNC is connected but I am sure I have seen on other forums that people have swapped between them for testing purposes. That would suggest it to be a fairly straightforward thing to do, so if you can describe your setup and how the cable connects to the computer it may help.
Pics of the control box internals may also provide some clues.
IF I remember correctly the WinCNC uses step/dir output so you would be able to rewire the PC directly to the Drives using a good BOB.
BUT you would not be able to use their motion control boards as per say.
Looks like it uses a pci card and daughter board to send signals to the servo drivers. These of which are from keling.
I have a router with wincnc.
I did try connecting Mach3 to see if it would be better than Wincnc.
I ended up staying with wincnc.
My router has steppers not servos though.
You can get the wincnc manual from here http://www.wincnc.net/ in the manual you can find out where the signals are probably connected.
I would be interested to find out if anyone has done a comparison with Mach3 with a motion controller like the smooth stepper vs. Wincnc.
Easy answer.....price ........so much for Wincnc in my opinion. ;)
I will probably try a weekend with a 12 pack and see if we can switch it over.
In comparison I think Mach trumps wincnc. There are more features at the click of a mouse. I dislike pull down menus and small buttons.
As with my website I stick to products that are either open source or relatively price friendly, because they seem to have the largest support groups and plug ins availble.
Wincnc is customizeable.
You can create your own screen, custom macro buttons on the screen, etc.. I found a thread a long time ago about that on the cnczone I think.
Price, well I agree Mach3 software is cheaper.
I have a lathe that I use Mach3 on, I love it but there is some kind of quirk where sometimes it will just freeze the computer. The only way out is to press the power button on the pc. I have a custom Lathe screen I created and I thought it was that but, it has happened using the regular lathe screen as well. I even tried a different computer and it happened on that as well. Yes I own a license so it's not an un-licensed copy.
In the 5+ years I have had wincnc, I have MAYBE once had it mess up on me. I have had Wincnc, Bobcad, Solidworks all running on the same pc at the same time, Running a job while Drawing a part in solidworks, then generating G-code with bobcad all while the job kept running in the background.
Not trying to bash Mach3, I really like it, the features, the support forum, i just have trouble with my lathe.
If I could have that kind of reliability in Mach3 I wouldn't hesitate to convert my Hardinge Superslant over to Mach3, probably even my (2) VMC'S too.
when you initially installed it, did it crash during the driver test.
What operating system do you have on your computer. I have xp and installed mach 3 on all of mine and never once had any problems.
per.
What does the Time in Int and the Frequency say on the diagnostics page? You will likely have to load a mill screenset to see these as I dont think they are part of the standard Turn screenset.
I don't remember it crashing during the driver test.
I have even tried un-installing, re-installing. Also have run the driver test more than once. The driver test looks O.K. not perfectly flat but pretty good.
The strange thing is, This PC worked flawlessly until the harddrive failed. i installed a new HD, Loaded win XP. Optimised for Mach.
