Mach Discussion => General Mach Discussion => Topic started by: Mariah on April 03, 2011, 11:22:49 PM
One part program that I have wrote and have run on my lathe several times is now causing Mach3 to shut down when I try to reload it. While it is scaning through the g code it just goes blank and shows my desktop. When this happens I must run the driver test to get Mach 3 to reopen. Other part programs load as they should with no problem.
What happened here? Can someone please help me with this? I need to get some parts made.
Mariah
Can you check what your CPU load is whilst opening the code.
Hood...I checked CPU and it's near 0% then spikes up to 50-100% for a brief second when the program starts loading.
Mariah
Can you try turning off the Toolpath Display (Diagnostics page) to see if that makes a difference. If not maybe attach your code and xml and I will see if I can get the same problem here.
I get the same problem if I have an error in the GCode - in particular the drilling cycle..for eg (on the mill version)
G73 Z-10 Q0 R10 F100
Its the Q0 it does not like - I edit this to say Q2 and problems is solved.
ATB
Derek.
I got this straightened out, entering G59 caused an error in my GCode so changing it to G52 got my program to display.
The thing that has got me into this is cutting an involute curve with a subroutine, I can't find a suitable way to move my tool Z- to take the next cut. Any advice will be much appreciated and thank you guys for the help with my GCode error!
Mariah
