Mach Discussion => General Mach Discussion => Topic started by: ostie01 on March 30, 2011, 03:09:23 PM
Would like to add a DRO for Rapid feed rate override.
On my pendant, I have a 3 positions rotary switch that I would like to use to set rapid feed rate to 25%, 50% and 100%
I use 3 inputs on the ModIO, no analog input available.
If for example, the switch is on position 25%, would like to write that value to that DRO, and so on for 50% and 100%.
I have tried to write a brain but stuck with it.
Is someone have any idea on how can I do that or any clue would be really appreciated.
I already set up a Spindle speed override, feed override and the third analog input is for the MPG selection mode.
Jeff
Any idea what the input format is in a Brain for the ModIO? Afraid I dont as I have never used one but the rest is easy enough.
That is the ''easy part enough'' that I have problem with.
I don't know how to do it with brain.
Jeff
Do you know what form the ModIO inputs are in a Brain. I know what the Brain needs in the Modbus ranges for my PLC but the ModIO will likely be totally different.
