Mach Discussion => General Mach Discussion => Topic started by: teccboxx on February 28, 2011, 11:35:40 AM
Looking into building a new pendant and was wondering on what everyones thoughts are on both of these items and which one runs better with mach?
I've never ude the PoKeys device but I have used other keyboard emulators and I think the modbus is more reliable.
Pokeys is not a keyboard emulator, it can be used as such but can also be used as digital I/0 and is the way I would recommend if going for it. Never used ModIO so cant comment on it. I used the PoKeys when messing with my pendant and it worked well, even the analogue inputs but I ended up using my PLC as it allowed 24v which I prefer in an industrial environment.
Didn't know that. I've never used ModIO either, but have also been using modbus through a PLC and it's worked flawlessly. I thought PoKeys was a USB device. Never had much luck with anything with a USB connection...Not with plasma anyway.
PoKeys is USB but it talks via a plugin. Never had any issues with it but that was way back in the early days so not tried it for a long time. Dont use Plasma so that may be something to keep in mind and like you say ModBus is rock solid so might be a better option, especially as normally 24v I/O is used with a PLC although ModIO may just be 5v.
