Mach Discussion => General Mach Discussion => Topic started by: judah on November 20, 2006, 01:56:45 PM
hey dose any one know if the z end should be a neg number on mine there are no neg Numbers at all on the screen shouldn't there be?
thanks
On my setup, Z+ is towards the tailstock and X+ is towards me.
When using the turn wizards, I just key in negative (-) values for Z, in the entry fields, when describing cuts towards the headstock.
Paul, Central OR
mine will not let me cnange to a neg number its allways pos
Here's a sample I just ran... Mach3Turn ver R2.0.011:
Paul, Central OR
ya see it will let you enter a neg number in z end mine will not and your and also in your z center
thanks for the help though any more ideas would also be appreciated.
I'm currently running Mach mill would this affect any thing?
Is it a mill or lathe you have? If it's a mill, don't use the turn wizards, if it's a lathe, you should be using Mach3 turn.
Hi Judah,
My setup is a P4, 2ghz, 1GB, Windows XP Pro SP2.
I'm currently running Mach3 ver RC2.0.013. When running Turn Wizards, I start Mach3 with "Mach3Turn.xml".
One more thing... I use my Numerical Ten Key Pad (right side of keyboard) for entering value signs (-), decimal point (.) and numbers... finishing with the "Enter" key on the bottom right corner. I don't know if there is any difference to the Wizard for which set of number keys are used?
Paul, Central OR
