Third party software and hardware support forums. => dspMC/IP Motion Controller => Topic started by: grahamatcadcam on January 25, 2011, 02:37:39 AM
Please advise how to reverse the servo directions in a MACH/DSPMC setup.
Changing the dir in PORTS and PINS in motor setup does not have any effect.
Regards
Graham
Hi Graham,
Go to the config tab then homing/limits. Change the red x to a green check mark in the reversed column.
Mike
Hi Mike,
Thanks we tried that today and it worked.
Can I respectfully suggest that some of these practical setuo issues should be in your manual>
Recerse direction and how to set up Slave Drives are 2 issues we have had on our current project!!.
Hi Graham,
While I did some work on the early manual I no longer update it since I don't work for Vital system.
I agree it would be a great idea to improve the manual with your suggestions and others that have come in from the forum.
I am unfortunately too busy to keep up with my own stuff at the moment so I can't do it even if asked.
When and if it slows down around here I will take a look at it, if not Rufi would be the person to make suggestions to.
I will answer questions on the forum as time allows as always.
Mike
I miss posted in the wrong forum.
My falt for having too many tabs open at the same time.
