Third party software and hardware support forums. => Galil => Topic started by: jmroberge on December 28, 2010, 10:03:24 AM
I recently added an encoder on the x axis of my router. The system controller is a Galil 2108 card from. The feedback is from a rack and pinion gear mounted on an encoder.
Does anyone know how to configure Mach3 to use the encoder feedback to drive the x axis rather than the open loop control that I currently have. Is this possible to do with this setup or does feedback only work iwith servo motor? I am able the see that the encoder does work properly in the Smartterm (Galil) as the motor position does increments/decrements as the position changes.
