Mach Discussion => General Mach Discussion => Topic started by: LB on December 08, 2010, 11:00:32 AM
Can Mach 3 read any of these programs? AUTO CAD DWG, AUTO CAD DXF, EMF, FMV, GEM, PAT, PCT, PLT, SVG, WMF, WPG.
Can I use Corel Draw with Mach 3??
These are CAD drawing formats Mach does NOT read them directly. They would need to be converted to a GCODE format. You cna use Corell with mach BUT the final ouput for Mach to be able to use it MUST be a gcode format.
Hope that helps, (;-) TP
Thanks for the help. We are now using Bob Cadv21, and would rather use Corel Draw. For us, it is much easier to use.
LB
