Mach Discussion => FAQs => Topic started by: dhellew2 on November 26, 2010, 03:48:53 PM
Can anyone help me?
I am using Mach3 and have a problem with the z-axis starting before the bit reaches the x,y position which causes the bit to start cutting before it reaches the proper position..
The g-code is correct (safe z 0.20) the following is a piece of the code.
N670G00Z0.2000
N680G00X0.0625Y1.9375
N690G1Z-0.1875F30.0
N700G1X11.9375F45.0
N710G00Z0.2000
N720G00X0.0625Y2.8125
N730G1Z-0.1875F30.0
N740G1X11.9375F45.0
N750G00Z0.2000
N760G00X0.0625Y3.6875
N770G1Z-0.1875F30.0
N780G1X11.9375F45.0
N790G00Z0.2000
N800G00X0.0625Y4.5625
N810G1Z-0.1875F30.0
N820G1X11.9375F45.0
Can you attach your xml please, probably a config issue.
Thanks, I hope this is the file you want. Dale
Solved the problem. Turned on and set the stop CV for angles >87° in general config. Dale
Sorry I never got back, missed your reply somehow :(
Good you got it fixed though.
