Mach Discussion => General Mach Discussion => Topic started by: dchutchins on November 23, 2010, 02:45:33 PM
Title: Light Machines lathe
Post by: dchutchins on November 23, 2010, 02:45:33 PM
This might not be the right directory to post this & if it is, please redirect.
I just purchased a Light Machines CNC lathe model 0400 & control box. I thought I was doing good and all I would need is a PC. Now I find out there is a special card needed from Intelitek that cost around $1000. Does Mach3 have a solution for this that is relitively inexpensive?
I really don't want to spend a whole lot more money on this machine as I purchased it as a trainer & I am planning on building a 7X or 8X lathe in the future.
Title: Re: Light Machines lathe
Post by: Hood on November 23, 2010, 03:43:45 PM
Do you have links to any documentation on the lathes motors and drives etc
Post by: dchutchins on November 23, 2010, 06:13:14 PM
I don't as of yet. It will be in shipment to me this week. Once I get it, I'll post all the specs I can find.
Post by: Hood on November 23, 2010, 06:37:23 PM
I did a bit of searching and really all I can find is that it uses 100 oz in steppers and for the spindle a DC motor.
I dont know what the drives are but it may be possible to wire them to a breakout board and work from Mach via the parallel port, if not then you would need new drives. Gecko does the G540 which I think would probably suit your motors (would need to find specs) and has a built in breakout board.
Spindle would possibly be a bit more involved, it depends what its drive needs as a signal but it may be possible to control it via the G540 as well.
Down side is the G540 has 4 axis and you only need two so it would be two drives sitting doing nothing, in itself not a problem but you are paying for them even though you are not using them. Suppose they would always be spares in case something went wrong although thats not likely as Gecko steppers tend to be very reliable.
Having said that it may work out just as cheap getting the G540 rather than a breakout board and two drives and then a spindle control card.
So worst case you are likely looking at $300 (obviously dependant on stepper and spindle specs) for the G540 and a bit of time wiring, best case is a breakout board and spindle board at probably around $100  or so.
Post by: dchutchins on November 23, 2010, 06:55:58 PM
Sounds like I am going to be talking to a lot of people at Cabin Fever this time around.
Post by: Hood on November 23, 2010, 07:12:39 PM
Yes thats would be a good way to get info, much easier if you can see the hardware while someone is explaining.
Post by: RICH on November 24, 2010, 06:23:28 AM
Lot of good folks at that show.
Carefull who you ask as a number of us moderators will be there and wouldn't want you to be led astray. ;D  ???  >:D
Post by: dchutchins on November 24, 2010, 06:39:51 PM
Hey, even G.I.G.O at this point would be very helpfull. This is definitely a learning experience. My wife is already pissed that I bought the Spectralight (light Machines) controler box & won't be using it. Maybe someone at cabin fever has been looking for one. It cost me $350 - ouch. It wouldn't be a bad deal if I could find the PC card cheap. It looks like Gecko & Mach3 is the only way to go now.
Post by: Hood on November 24, 2010, 06:42:47 PM
The drives inside you box may be usable, just need to find some info on them.
Post by: dchutchins on December 02, 2010, 01:23:50 PM
I now have the lathe in question in my custody. I have looked at the motors & this is what I have:
Superior electric slo-syn. syncronous/stepping motor. Type M062-CF-401E. hold 125 oz in. steps 200 per rev. 4.75 VDC 1.7A. spec A215922. Cont. Duty. 65degree rise. Class B insulation. Impedence protected.
http://mcsupplyco.com/uploads/productlayouts/ProductDetailDisplay.asp?DirectLink=true&ProductID=1202
There are 4 wires connected to the plugs & 8 pins on the plug. From the way the motors are mounted, starting at the top of the plug I have gray, skip a pin, red w/blk stripe, skip a pin, yellow, skip pin, green & next pin is blicked off as a locator.
Luckily the plug on the end of the motor is a standard punchdown type molex plug so I can rewire the machine & still reuse the motor plugs. This machine is definately built on a Sherline platform.
Post by: RICH on December 02, 2010, 05:13:13 PM
We need info on the drives which are inside the controller box. Do you now have any info on them?
If not, can you take some pictures of the inside of the controller?
Post by: dchutchins on December 03, 2010, 11:09:03 PM
I have 9 pictures of the controller box but I don't know how to list them on here. It appears that it is just a transformer, a breidge rectifier, a large circuit board, an input from computer (from propriatary PC board), machine outputs (one for lathe, one for mill, one for spindle & one for robot) & a bunch of external fuse holders. If someone can give me an e-mail address to send them to, I'll e-mail the pictures. The pictures are all about 2mb each. I think considering I paid around $350 for this box, i'd be better off selling it to someone who has the PC card but a dead controller & just purchase the GEKO system. There's a guy listing them (Geko) on e-bay that has the whole 9 yards in one package for around $400. I tried to build a new PC to run this thing. I got it all togeather & can't get it to work. With as much as I hate computers, I don't know why I started into a computer centric project.
Post by: RICH on December 04, 2010, 06:42:25 AM
Resize the pics so they are smaller, then to post them, click the Preview button and then click Additional Options.
You can use the Browse button for selecting what you want to attach.
Post by: dchutchins on December 04, 2010, 07:34:34 PM
pictures - first 4
Post by: dchutchins on December 04, 2010, 07:39:01 PM
pictures - second 4
In all reality, this controller would be good for someone who already has the PC card but the controller box is bad. I think I would rather keep it whole & sell it to someone who needs it & just purchase the GEKO system. The first person who offers me $350 or more gets it. I just need to figure out what the replacement would be in my case.
Post by: dchutchins on December 21, 2010, 06:46:24 PM
Well, I purchased a 2 axis controller/driver set from XYdrive Automation & in the meantime I placed the Spectralight controller on e-bay. A couple of days after placing the old controller on e-bay someone sent me a message that they have created a diagram for an addapter cable that allows me to hook the old spectralight controller to the PC parallel ports. I mad the addapter & connected everything. I soon relized the there is a crap load of cinfiguration settings in MACH3 turn of which I haven't a clue about. Is there somewhere I can look for an instruction manual so I can stop being clueless?
What would be cool is if there were someone in Northern Delaware that could come by & see if I have this thing configured right or if I have everything all messed up.
Post by: Hood on December 22, 2010, 02:46:51 AM
There is the manual for Turn if you go to the documentation from the support tab above.
What is it you are not sure about?
