G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: kak on November 13, 2010, 03:03:55 PM
Hello
Im running simulations in VisualMill, adding tabs/bridges (2,5D profiling) to keep my part inside the material, but all 3D toolpaths are milling the bridges away. Is it normal? When I choose outline of my part as a machining region and run 3d finish path with a ballmill, there is a little bit of the briges left ( not enough), because my tool stops when it reach the machining region, but if I choose the region a little bit outside the part, the bridges are gone.
How can I keep the part inside my material or just the same place? I don`t have any holes in the part, its just a 3d surface.
