Mach Discussion => General Mach Discussion => Topic started by: jzavazal on October 31, 2010, 10:28:43 PM
When I click in 20 mm table only move 10 mm. What is wrong?
Hi, please provide a little bit more info about your setup.
Sometime, this is due to wrong calculation of step per inch or mm.
Please download the Excel file on this link and verify your math.
http://www.machsupport.com/forum/index.php/topic,16315.0.html
Jeff
Sounds like you have entered half the amount of steps per unit necessary. There is a calibration feature. It will ask you how much you would like to move, then it moves ( the amount entered) and then asks how much the machine actually moved, then it will correct the steps per unit if you accept it.
