Mach Discussion => General Mach Discussion => Topic started by: stjohn4 on October 21, 2010, 03:33:56 PM
Hi Guys,
I have a question about getting the taig cnc micromill 2000 which is in the quantum cnc enclosure up and running. I am using a thinkpad T40 laptop with windows 98, mach3 and connecting the micromill2000 driver box to the laptop parralel port. I downloaded the mach3taig2000.xml config file and fired it all up accordingly. Axis x,y and z all work via jog at 50% speed reduction. Jogging at 100% caused the z-axis stepper to slip. My problem now is that I can't get the spindle to run (ac induction motor, belt driven). I would think it would be relay controlled with either an on or off condition (M3 does nothing). The emergency stop button on the quantumcnc cabinet also does nothing. Any suggestions how I can get the spindle going and how I can get the e-stop button working?
The spindle motor does work as I can get it to spin up in manual mode.
I am completely new to the taig and mach3 so any help or suggestions are greatly appreciated. I have read the mach3 documentation but think most likely I would benefit from some expert advice here...
many thanks,
St.john
WIN98 MAY be a problem the MINIMUM spec is W2000.
Just a thought, (;-)
Umm... back to the drawing board!
Changing that and testing again now..
thanks
St.john
Also be aware that Laptops are not officially supported as they can be very problematic with the Mach Driver, some work fine others dont.
Sorry - slight correction. I am running windows XPpro which should be fine as it is above win2k...
Any suggestions?
thanks,
St.john
Hi Hood,
yes I was aware of that, just giving it a go as a laptop is all I have spare at the moment. Would I be right in thinking that if the x,y and z axis where all playing nice I should be able to get the spindle going also?
cheers,
St.john
I would think so but as Terry says W2K, XP, Vista and W7 are really what you need. Never tried to run with W98 so cant say what would or would not happen.
I dont know anything about the taig but by the sounds of it you have a relay to operate the spindle, have you got that set to an output? also have you got the output set correctly on Ports and Pins Spindle Setup page?
yes, I have xp pro setup. The spindle is operated by a relay. I am not sure now to find out what output the relay is set to and thus not sure what output to set on the spindle ports and pins setup page. I suspect that in not correct. Any ideas how to check that out?
many thanks,
St.john
Do you have a link to any documantation on the mill? Failing that really the only way is to physically look and see which pin the relay is connected to. As for which output, it doesnt matter as long as you have the correct port and pin numbers set up to that output
Hi Hood,
the documentation that Taig make available is an absolute joke. They seem to be stuck in the 1970's and believe DOS is the forefront of user interfaces. I contacted them and they gave me some crazy info about using it in conjunction with their driver which I know for sure would be a disaster. Unless someone tells me otherwise looks like I will have to open up the controller box and start following wires and counting pins...
cheers,
St.john
Where did you get the xml from?
You say that SOME things work. I woulld look at the setup info in mach and write down the pins used for the things that work. That should leave a short list of avalable pins to use for the spindle relays.
Just a thought, (;-) TP
Hi Hood and BR549,
there is a taig specific .xml in the mach3 ftp download area, there is also on supplied by Lester caine and I am now going to test one supplied by taig themselves (microproto). If that does not work I will open up the control box and start working back from there with a view to understanding the pin and relay setup.. (wanted to avoid that if someone had already done it..)
cheers,
St.john
St, John,
Make sure you're downloading the correct xml as I believe there's quite a difference between xml's for the Taig 2000 and the Taig DSLS 3000 systems.
I'm not at all familiar with the 2000 system but it is not the same controller setup at all as the 3000 and with the 2000, I think you need some sort of "pulse- adapter" to run the 2000 with Mach 3. Don't quote me on that, but I'm remembering something to that effect ;)
I have this all functioning now. The enclose needed the 'run' switch to be set on then it all appears to work. I will play with it now and see how it performs.
many thanks,
St.john
Hi all, new to mach3. I am having trouble setting up mach3 to run a taig mill. I have downloaded the suggested xml file from this discussion, but where do I place the xml file? thanks.
The .xml file is placed in your Mach3 folder.
Oh thats simple enough then! Thank you. Was looking for an option in the menus to import one.
I recently had my mach3 pc hard drive die on me so I set up another old pc to run mach3 and fitted my parallel port from the old machine into the "new" one. Now I am unable to get the machine axis to move even though the mach3 DRO shows movement.
I am currently using an old mechatronics bi-polar micro stepper driver and today I think I have found the correct information for the pinout number for each axis. I will see if I can get mach3 to talk to the machine using that information today. I even bought a new mach3 license yesterday as I was sure everything would work but instead ran into lots of problems. Lets see how today pans out. :)
Nope! no joy with getting any axis to move. I think I am out of options now and tried everything I can think of including days of research looking for ideas. It seems that my time with mach3 is up :-\
