Mach Discussion => General Mach Discussion => Topic started by: Digilife on September 25, 2010, 08:00:52 PM
HI GUYS, DOES ANYBODY KNOW HOW CAN I CREATE A BUTTON TO JOG AN AXIS INDEFINETLY.
THANKS IN ADVANCE. :)
SUre but NOT while doing anything else like running gcode(;-)
ITS NOT TO RUN ANY CODE IS JUST TO CONVERT A PC ON A HIGH SPEED (45KHZ) STEP GENERATOR FOR A CUSTOM MACHINE WICH USES AN STEPPER MOTOR TO MAKE ITS WORK, ALSO IS IT POSSIBLE TO JOG ALL X,Y,Z,A,B,C AND HAVE INDEPENDENT FEED CONTROL ON EACH OR JUST A GENERAL FEED CONTROL FOR ALL OR THE ONES THAT YOU ACTIVATED TOGETHER FROM 1 TO 6?
** OK
** NO
** SORTA
