Mach Discussion => General Mach Discussion => Topic started by: Tristar500 on August 13, 2010, 12:38:21 PM
I'm having a terrible time trying to get the mach plugin to work. (not the wizard) :(
I get a "Previous SEQ not yet complete error" as soon as I start the probing routine.
Somewhere else here I saw a post about the plugin not working with the newer versions of mach?
I'm using the Smooth Stepper so I can't go back to Mach 2
Any solution here?
AFAIK this is still the case. Other probing routines are available though.
Where might I find another probing routine. (other then the painfully slow "bed of nails" method)?
you could try http://www.razordance.co.uk/probe25D.htm (http://www.razordance.co.uk/probe25D.htm)
for a full background see http://www.machsupport.com/forum/index.php/topic,4352.0.html (http://www.machsupport.com/forum/index.php/topic,4352.0.html)
