Mach Discussion => General Mach Discussion => Topic started by: Smackre on October 20, 2006, 07:53:30 AM
Well i just ordered a Ekstrom Carlson Spindle to replace my porter cable. I just couldnt deal with the run-out any longer.
Can anyone give me a rundown on the best way to wire the VFD to mach3? The simplist way.
Do you have a breakout board with an analog output?
My breakout board is simple. All it has it the lpt port and blocks to connect wires. I do not think it has a analog output.
Does your VFD have to see a varying input voltage to vary the speed? Any VFD I have fooled with works this way. Do you have any wiring diagrams you can post, or a link? Look at these and see if it helps.
http://www.campbelldesigns.com/mach-spindle-speed-control.php
http://www.cnc4pc.com/Variable_Speed_Control_Board.htm
