Mach Discussion => General Mach Discussion => Topic started by: Fleck on July 18, 2010, 09:29:43 PM
I am just learning Mach and am having a intermittent issue when trying to use work offsets.
Sometimes I can go to g55 zero, but mostly all is stopped and status gives a safe z is turned off ignoring safe z move.
If I restart program I cane go to zero again. I have turned safe z on and when I do that, I get no move and no message. I am using a k2 3925 servo equipped with limit switches. Any advice is appreciated.
Thanks Mike
How have you got safe Z set up?
How are you commanding the move to "g55 zero"
Thanks for the reply.
My machine is new and until this week safe z has been turned off, but I now want to use work offsets. I have tried turning on safe z with a value of -.5,0 and .5 to machine coordinates with no success. I did not close and re-open program after making the changes, maybe I should have.
When I turn safe z on "Go To Zero" doesn't work at all, nothing is listed in status bar as a problem.
I have machine offset coordinates set up in offset box for G55 where I would like G55 0 to be. When I turn machine and CPU on, I am going directly to offsets tab and switching from G54 to G55, then I go back to program run and use the "Go To Zero" function. Sometimes it works. If it does not work I have to restart CPU for "Go To Zero" to work again.
Thanks again.
Mike
A safe Z in Machine Coords should be no higher than 0 or should be a negative number, this is because your zero for Z axis is fully retracted when in Machine Coords. So your -0.5 should be fine but the +0.5 is not.
As a test use the MDI Line and type in G55 and see if the coords in the X Y and Z DROs change.
Also if you can attach your xml for the profile you use I will have a look.
After restarting CPU yesterday with safe Z changed to ON at a Z value of 0 machine, things seem to be working well. I am pretty sure some of my problems are coming from trying to learn how to setup G55,56 etc. .
Mike
