G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: rustymcknight on July 13, 2010, 11:20:50 AM
Can I run the mach3 mill demo without having any electronics hooked up on my computer. I simply want to run a gcode demonstration on the software i downloaded. The reset button will not allow me to turn it off to proceed.
In ports and pins, toggle the active low setting of the Estop pin.
Inputs, I think.
If that dosn't work just assign an unused pin number, enable estop, and check Emulated
in CONFIG>PORTS & PINS>INPUT SIGNALS
Any G code to simulate E- stop end of the program? thanks.
