Mach Discussion => General Mach Discussion => Topic started by: learman on June 28, 2010, 12:42:51 PM
Hello All
Trying to jog my x axis +.020 once if input 4 is not active, (Pappabear) or scott was kind enough to get me started but im still needing some help!
Scott wrote this
well it might be easier to put a custom macro at the start of your g code file.
i.e. M1000.m1s
I am not at my work computer so you will have to look up the OEM VB codes below.
You might want to double check my VB also, but you want to look for your input being active.
INPUTx below could be INPUT1-4 (or you could use the OEMs 1-15).
also on your general config page, you will need to set up your Step jog DROs with at least one of them with the value
of 0.02 in it, let us say that is the first value box.
'M1000.m1s
MyNeededInput = IsActive(INPUTx)
If Not(IsActive(MyNeededInput) Then
If Not(GetOEMLED(*********)) Then 'look up the OEM LED code for the Machine is in Step/Jog mode (not continous or MPG).
DoOEMButton(*********) 'Do the button to put the machine into Step/Jog mode.
DoOEMButton(*********) 'set the step jog value to the first dro value box OEM button
DoOEMButton(*********) 'Push the Jog Button for the X+ direction
While IsMoving()
Wend
Else
While IsMoving()
Wend
End If
End if
'scott
If Not Is Active (Input 4) Then
If Not(GetOEMLED15) Then This is for Jog Mode Incr
DoOEMButton(15) 'Do the button to put the machine into Step/Jog mode. (?? im lost here)
DoOEMButton(193) ' Select Jog increment 3, i have set it to .020
DoOEMButton(307) 'Push the Jog Button for the X+ direction
While IsMoving()
Wend
Its a start I think ???
josh
