Mach Discussion => General Mach Discussion => Topic started by: tjfisher26 on June 05, 2010, 10:22:01 PM
Hi all im new here i have a delmia if i jog all my motors the run great the move smoothly the run 1" for 1" but once i run a g code and start a cycle the act up the make noise but no movement and then the move a little . anyone have any ideas ?
run 1" for 1"
That you chose the correct step per unit
make noise
you must check "velocity" and "Acceleration"
i think These values were selected high level.
ok so lower the velocity and acceleration ?
yes. It test with different amounts
ok so that has fix the problem thanks alot manmardam ;D all i need to do now is slowly bring up the numbers and find the balance point :)
result :)
there will come a point where they start to misbehave, just back away from this by a few % and all should be well.
repeatability testing is next, sending the axes on a long journey around the table and making sure they return properly to where they started, but since I found the happy maximum speeds and accelerations for mine this has not been a problem.
