Mach Discussion => General Mach Discussion => Topic started by: andyk01 on May 19, 2010, 11:37:51 PM
Hi, Just a quick question (I Hope).
I have built a CNC Plasma table (My first) controlled by Mach 3 and need to connect three different parallel devices...
Machine Control, LPT1 (4 Axis and the usual e-Stop, & Home switches)
Torch Height Controller, LPT2 ( Bob Campbell THC 300)
MPG, LPT3 (4 Axis ) As the machine is 15' * 8', jog from the keyboard is not practical when setting up large jobs.
Can this be done??
Andy K
No. Mach3 supports only two PPs.
you must use modbus for Handheld Pendant
I wish it did too.... My VMC Project could use it.
JH
i build modbus pendant with AVR for mach3, up to 32 key.
programmable with brain
There are many different types of pendants that do not require Modbus at all, take a look at the one Bob Cambell carries as well as the one from Polabs...
OK. So a third LPT port is not an option...
This leaves me with either Modbus or a keyboard emulation device such as Pokeys55. For me, I think the Pokeys55 will be quick, simple and cheap to use with my TTL pendant from Keling inc.. So the question I have before getting out the credit card is "will pokeys coexist with a keyboard"? Mach3 being a windows app, it's difficult to drive long term without a standard keyboard.
Thanks, Andy K
The PoKeys is not just a keyboard emulator, it can also be used as true digital inputs. If used as an emulator then yes it will coexist with a keyboard but much better in my opinion to use it as digital I/O.
how about a wireless keyboard?
I am working on it
