Mach Discussion => General Mach Discussion => Topic started by: Kato on October 10, 2006, 01:32:24 PM
Hi, I have bought a "breakout board(C10)" and a "variable speed control board(C6)" from cnc4pc.
I have problem to make it work with Mach3. Can anyone who also got the same boards tel me how you have setup your Mach?
I'm totally new too Mach. Even the simplest settings would be helpful.
Thanks/Jim
Tell us more about your setup. What is it on? Is it a retro? I don't have those boards but I would think all breakout boards would be set up the same. Go into config., ports and pins.. Do you have a straight through cable. (Not a printer cable) Do you have power hooked to your board?
Its an ORAC. I use the original vfd and step motors. Using Gecko 210 for them.
I got 5vdc connected to the breakout board and 12v to the C6-board. A relay to start/stop the spindle.
At ports and pins I have choose port 1; pins 6,7. Low active.
At the spindle setup I have set: port 1 to the relay, Motor control by step/Dir,
Output signals enabled pin1.
Just consentrated me on the spindle right now, taking it step by step.
Would like to be able to measure the 0-12v output on the C6. But I only get 0v
/Jim
I think Kato is trying to set up the speed control board and the VFD to control the spindle speed through Mach.
My bad. Had me lost as a f_ _ t in a whirlwind. Duuuuuuuhhhhhhhhh. Yea, that makes sense. ;D
Do you have E-stop enabled in ports and pins, output signals? Did you download the drivers for Mach? Do you have a switch, or jumper, safety chargepump, to enable this board?
I have tried both enabled and disabled the E-stop. Right now I don't have anything connected through the real E-stop, just connecting one thing at the time to be able to measure everything up. What drivers? The breakout board is enabled by a switch now. In "outputs signals" I only enabled output#1 for my start/stop relay.
When you download Mach, It asks if you want to download drivers. I will try to get you my settings in ports and pins. Maybe this would help you.
That would be perfect.
Here are some pics. Hope they are clear enough. If not, I'll type them out or something. All I have set up on mine is the motors. Look at the pic. titles. The names have the tab in ports and pins that the pic. is of. I think I will have to put these on two post. Too many pics. :)
One more pic.
Brett, instead of having to use a camera you can grap screenshots by pressing the PrtScr button on the keyboard, this will take a snapshot of the whole screen and you can then paste it into your favourite graphics program for editing, or even into word etc. If you press Alt+ PrtScr it will only take a snap shot of the active window.
I use a really handy program for screen capture, its called ScreenHunter 4.0 free , the beauty of it is it will save the image directly as a JPG (no pasting required) in the location of your choice ready for posting to the net etc, you can also configure a hotkey for taking the shot and can choose how you want the area to be selected. You will find it here http://www.wisdom-soft.com/products/screenhunter.htm
Thanks Hood,
I Hope you stick around, your as handy as a side pocket.
Thanks Chaoticone, I get signals for cw and ccw. Just one more problem. I only have 0,07v at maximum speed. But I didn't have much time today to look my set up. I believe that is an simple miscalculation.
/Jim
