Mach Discussion => General Mach Discussion => Topic started by: morarudnl on March 28, 2010, 09:21:20 AM
Hi all,
I have this problem with mach3.
Can anyone help?
Tanks a lot.
Has this just started or is it a new install?
How do you get that, is it just as you try to start Mach?
What version are you running and is it licenced or just a demo?
Have you tried re downloading from Machs downloads page and reinstalling?
Hi Hood,
I work with this installation about 2-3 years, without any problems.
Some day when I started Mach3 appears this message.
I have buy Mach3 lic. ( for SCULE ARAD)
This messages appears with old installation, and wen I reinstall with new version, this messages appears again.
I remove Mach3 from my computer, and I reinstall with last version but this message appears again.
Tank you very much Hood, and all, for any suggestions.
Daniel.
I will see if Art can have a look as he is probably the only one that will know what the Artcode means.
Hi:
Does it happen with Mach3Turn? Or how about trying a new blank profile?
Art
Hi Art,
It happen with mill Mach3.
Mach3Turn works, and Mach3Plasma works only x and z axis, y don't work .
Only Mach3Mill and new mill profile appears this message.
Tanks Moraru Daniel.
Hi:
Hmm, zip the xml profile and post it here and Ill see if I can find the problem, must be a setting somewhere..
Art
Hi Art,
This is all files .xml from my Mach3 profile.
Tanks,
Daniel.
Hi:
Im afraid it works fine here.. Mach3mill.xml does anyway.
I notice you have a file with no name ".xml" , delete that file and any xml's you dont use and see if that helps..
Art
Hi Art,
I solve problem, I remove all mach3 components from my computer and I reinstall mach3.
Until now mach3 run OK.
But I don't know why the message appeared.
Tanks for advices.
Moraru Daniel.
I was having this same issue. Tried creating a new profile but got the same error.
Not real sure where it hung up, I got the splash screen and then the error. Art Code:1
So I started removing unneeded things.
tracked it down to a plugin issue, the ShuttlePro.dll I move it out and no more error.
I put everything else back to where they were.
So have to assume an Art Code:1 is for a plugin load error or some kind of conflict with another plugin.
Hello,
This message appeared when I had not installed any plugins. I intend to use PoKeys55 plugin.
I solve this problem after I remove all components of Mach3 (Mach3 directory and drivers), after that , I reinstall Mach3 and, until now, all work fine.
Moraru Daniel.
I had read what you did to solve your problem. I too had not added any plugins, I was working on creating screen sets at the time.
Mach3 just failed to start one time, So I was explaining how I tracked down my problem. Thought it might help others. My post was not ment for you, it was just a general post to others who might see this error and freak.
I'm testing a new plugin, it works on the developement machine but on a plain xp pc it triggers " Error triggered Art code: 1" at startup.
Any hint about what is triggering this message? ???
If I remove the experimental plugin there is no error and Mach3 works fine so I'm fairly sure Mach3 is properly installed on both the machines.
