Mach Discussion => General Mach Discussion => Topic started by: piv on January 23, 2010, 09:56:40 AM
I am trying to find out if mach3 can be setup somehow to do do 5 axis kinematics, also known as RTCP (Rotation about Tool Centre Point) so you can program a five axis toolpath at the tip of the tool and do the tool length compensation in Mach3. Is this what Formulas is used for? Ive only got a demo setup at the moment, with a DSPMC clearing customs so I can try it out on a 5 axis CNC router next week. Its a bit hard to tell from the demo exactly how it will work with DSPMC as I have to have the DSPMC to run the plugin.
Also is it possible to somehow program on an inclined plane (or coordinate transformation), this is often used in 3+2 machining so you can program as if its a three axis job but then say machine on a face inclined at 39 degrees with the spindle at right angles to the inclined plane.
My guess is I might need to write a plug in to do this, unless someone else has done it, is working on it, or volunteers to do it. Im a newbie to Mach3 so writing a plugin will be a big learning curve. The docs ive found on plugins are for mach2 or am I looking in the wrong place or is it still the same?
I don't know the details of how Mach3 handles the moves, so don't know if a plugin can be made. I DO know that 5 axis kinematics are not supported with Mach3, and I just guess that since all the moves are handled in the trajectory planer, it is unlikely that a plugin would work for this.
Daniel
I've read somewhere that the moves were going to be handled outside of the trajectory planner but I dont know if thats happened yet. A kind of work around is possible if the CAM package writes the G code moves close together, then the transformation/kinematics can be done on the G code file before it goes to the trajectory planner, not perfect, but it gives the same good result that you get if the CAM package puts out joint positions rather than TCP (Tool Centre Point). A similar thing could be done for machining on an inclined plane, except a reason for doing that is so you can program circles and arcs with G02 G03, which really needs the transform to happen in the trajectory planner.
I've seen a site were they are using gmax? and a plug in to write gcode for 5 axis milling, I'll try to find it again and post the address for you.
Steve
Just found it
http://cnc4free.org/
look under essentials then cnc toolkit
More for hobby/ small business use but may be of some help.
Steve
hiya guys,
ive had good results with cnc toolkit
ive also had good results with 'cheating 5axis' by rotating head and then re zeroing and cutting 3 axis with a tilted head.
Im thinking about doing the math and code for one of 2 things:
a gcode modifier that you feed in 4'5 axis offsets then it will filter 1,2,3 axis locations. effectively doing what cnctoolit does very well already.
I was also thinking about using the math formula feature in mach3 to do the same thing but suspect it would slow down with all but the coarsest 5 axis movements, again this would work if you only moved 4,5 axis ocassionally while off the work surface. I could live with this as i think good work is possible if you keep life simple.
Can you let me know what you made of the vitalsystems DSPMC, im thinking of ordering one shortly and would love to hear your expereince.
regards
Benergy
I have Madcam. A 5axis cam software. It's 3+2, maybe 4+1. Supposedly true simultaneous soon. It has a Mach post processor. I haven't used it yet but in searching for a cheap 5 axis cam.. it seems very capable.
Ive got DSPMC on two 5 axis routers and it is very good. Rufi is developing a "point streaming" plugin so that we can send 1ms points to the DSPMC. This will allow an external software (user to write it) to do kinematics and trajectory planning outside of the cnc. The idea is that I will write a program that takes the g code and interprets it and does trajectory planning and kinematics, then the plugin streams that file to the dspmc. It will have lots of limitations but will enable user control over accelerations and limits and kinematics that is not possible within Mach3 alone. ITs all vapour ware at the moment.
Hiya Piv
so thats a thunbs up for dspmc then. you run steppers or servos? How are you toolpathing your 5axis?
b
Machines are running servos in torque control mode.
Toolpathing is by Topsolid and Mastercam. Have other machines on Unigraphics NX and ProEnigneer.
I should add that Topsolid and Mastercam can do the kinematics so they just output axis movement, not the tooltip.
Sorry but Mach does not do kinematics so it cannot Jog in world mode( Tooltip mode) All kinematics MUST be accounted for by the CAM software for running the gcode side.
Yes you are right, Mach3 does not do kinematics. But some CAM packages can do the kinematics. But you cant tilt the tool and then jog in the tool direction. But you could write a macro that could do that kind of manual move if you needed to.
As long as the 5 axis toolpath is short straight lines mach3 can process poor man's kinematic motion with tool length compensation, even compensation for bad rotary head alignments, provided some vector formulas are inputed, the downside is no true jogging. Unless you use mdi, what would be good is a step based mdi jogging routine(10mm at a time?), i ll look into this when i get some free time and its raining.....
Piv, i never noticed mastercam having kinematic computed outputs, where are the head values set? I assume It wont do kinematics for heads with b and c offsets like CNC toolkit? ...or did you mean 'cant' rather than 'can' in the last post.
I really do like toolkit...
I still swear by indexed head machining for big curved open surfaces on routers...it's like overdirve on the autobahn compared to 2nd gear round the back streets.
Mastercam needs the right post for doing the kinematics. We got one and the head axis offsets and pivot lengths etc are all variables in the post setup file that can be set. It was about 7 years ago for a customer so its testing my memory.
When you say for Mach 3 the vector formulas need to be input, can you give a short description and example of how that is done please? Is it through the formulas menu?
