Mach Discussion => General Mach Discussion => Topic started by: LockTech on January 01, 2010, 12:33:46 PM
How do I change the order of which axis returns to 0 first? For example currently it is X & Y first then Z last, but I would like for it to be Z first then the other two axis.
You have to edit the VB code
You do OPERATOR, EDIT BUTTON SCRIPT
All the buttons start flashing you just select the one you want
You have to be on the page that has the button you want to edit
Then just swap them around to suit
Phil
Just turn on SafeZ
