Mach Discussion => General Mach Discussion => Topic started by: omri on December 22, 2009, 08:45:17 AM
I believe its' a bug, Therefore, I put a bug report in the appropriate place, however, maybe any of you can open my eyes:
I have been running mach occasionally for a year now, all in all it went ok. however, I did mind that I had sometimes I needed to cancel the CV to get a proper corner. So, I went on and changed that on the config, for corners > 44.
The computer is a 2.5GHz, 2GB ram, winxp sp3.It is only running mach, commanding a router.
I used version 3.042.020 for most of the time. however, when I ran into problems with the steppers humming lately, I decided to upgrade to version 032.
Version 032 runs on my machine badly: it doesn't obey the velocity limit, and runs my steppers 1.4 times faster than the 020, and it didn't solve my stepper hum problem. so I downgraded to 029. the 029 obeys velocity limit, but still carries the same problem.
FINALLY: the problem description:
I run various g-codes. one of them is attached here below. the most run without any problems, however, this one caused humming. So I cut the velocity and accel in half, and still it humms. the funny thing is, it starts the humming when in full speed, without any apparent reason. when jogging it gives no hum at all, even though the jog is even faster.
IMPORTANT: I found that when I run the code with different lookahead(tried 1, 2, 5, 20, 50, 200, 400, 500, 1000), it does the humming on different program lines, but it is always the same line per lookahead value.
This humming causes loss of steps of course, and the programs keeps running from the supposed position, which is already wrong.
I really believe it has a strong relation to the lookahead, please help, I really have no solution, this experimental piece of code that is attached demonstrates all the problems. all it does is v-carve a rectangle, then with a 10 mm flat it makes a bottom, then a 25.4(1``) ball it makes another inner slope. supposes 19mm thick mdf.
G00 G49 G40.1 G17 G80 G50 G64 G90 G58
G21
(V-Carving 3)
M6 T1
M03 S4851
G00 Z60.0000
X96.0010 Y26.0010
G01 Z13.0000 F3000.0
X101.8451 F3500.0
G17
G02X96.0010Y31.8451I0.1549J5.9990
G01 Y26.0010
X95.9010 Y25.9010 Z13.1000
X96.0010 Y26.0010 Z13.0000
Z60.0000 F9000.0
G00
X102.0000 Y273.9010
G01 Z13.1000 F3000.0
X338.0000 F3500.0
G02X343.9010Y268.0000I0.0000J-5.9010
G01 Y32.0000
G02X338.0000Y26.0990I-5.9010J0.0000
G01 X102.0000
G02X96.0990Y32.0000I0.0000J5.9010
G01 Y268.0000
G02X102.0000Y273.9010I5.9010J0.0000
G01 Z60.0000 F9000.0
G00
X95.9010 Y274.0990
Y25.9010 F3500.0
X344.0990
Y274.0990
X95.9010
X96.0010 Y273.9990 Z13.0000
Y268.1549
X96.0151 Y268.4394
X96.0167 Y268.4555
Z13.0004
X96.0000 Y268.0000 Z13.0010
X96.0161 Y31.5507 Z13.0002
X96.0167 Y268.4555 Z13.0004
Z13.0000
G02X101.5445Y273.9833I5.9822J-0.4544
G01 Z13.0004
X102.0000 Y274.0000 Z13.0010
X338.4493 Y273.9839 Z13.0002
X101.5445 Y273.9833 Z13.0004
Z13.0000
X101.5606 Y273.9849
X101.8451 Y273.9990
X96.0010
Z60.0000 F9000.0
G00
X343.9990
X344.0990 Y274.0990 Z13.1000 F3500.0
X343.9990 Y273.9990 Z13.0000
X338.1549
G02X343.9833Y268.4555I-0.1546J-5.9983
G01 Z13.0004
X344.0000 Y268.0000 Z13.0010
X343.9839 Y31.5507 Z13.0002
X343.9833 Y268.4555 Z13.0004
Z13.0000
X343.9849 Y268.4394
X343.9990 Y268.1549
Y273.9990
Z60.0000 F9000.0
G00
Y26.0010
X344.0990 Y25.9010 Z13.1000 F3500.0
X343.9990 Y26.0010 Z13.0000
Y31.8451
G02X338.4555Y26.0167I-5.9983J0.1546
G01 Z13.0004
X338.0000 Y26.0000 Z13.0010
X101.5507 Y26.0161 Z13.0002
X338.4555 Y26.0167 Z13.0004
Z13.0000
X338.4394 Y26.0151
X338.1549 Y26.0010
X343.9990
Z60.0000 F9000.0
G00
X90.0010 Y279.9990
G01 Z19.0000 F3000.0
X95.9010 Y274.0990 Z13.1000 F3500.0
Z60.0000 F9000.0
G00
X349.9990 Y279.9990
Z60.0000 F9000.0
G00
X349.9990 Y20.0010
Z60.0000 F9000.0
G00
X90.0010 Y20.0010
X95.9010 Y25.9010 Z13.1000 F3500.0
G00 Z60.0000
(Engraving)
G53 X150 Y1740
M6 T20
M03 S4851
X102.0000 Y32.0000
X220.0000 F6500.0
X338.0000
Y150.0000
Y268.0000
X220.0000
X102.0000
Y150.0000
Y32.0000
Z13.0000
Y150.0000
Y268.0000
X220.0000
X338.0000
Y150.0000
Y32.0000
X220.0000
X102.0000
G00 Z60.0000
(Engraving)
G53 X150 Y1740
M6 T3
M03 S4851
X107.0000 Y37.0000
X220.0000 F6500.0
X333.0000
Y150.0000
Y263.0000
X220.0000
X107.0000
Y150.0000
Y37.0000
G00 Z60.0000
G00 Z155
M5 M9
M30
one more thing: the missed stepper steps always happen on a line that has a z move line following. ???
Hi Omri
Don't know if this is any help but I just ran your code without issue other than it scared the pants off me because I don't usually use feedrates that high.
I only cut air, with the spindle motor switched off, but there were no unusual stepper noises and as far as I could tell no missed steps.
My PC is running Pentium4 at 2.4 Gig with WinXP Sp1(I had mega problems with Sp2 onwards) and Mach R3.042.032.
Just out of curiosity - Can you set your motors (vel. and accel.) to a high rate which works OK in the motor tuning page but then they stall when jogging in the main Mach window ?.
Hi Tweakie,
Well, I tried all sorts of configurations, and was able to cause missed steps while jogging. it happened when I tried a high frequency (45KHz) which enabled me a higher speed on the steppers, and since I use a gas spring to balance Z, the very fast up move caused missed steps midway up. it was too fast for the spring.
I really think this is a mach issue with my configuration, how can you explain otherwise that the missed steps happen in different portions of the code for different lookahead value, and that the missed steps are perfectly repeatable per lookahead value??
Thanks for your kind help. we now know for sure that the code is 100%. I''ll appreciate any idea, since I'm out of new ideas for finding this one.
I too have found that velocity behavior is overfeeding with version 0.032.
Please fix this.
I see that you are getting the error in a jog... that may be a problem with phase jitter.
Also I see you say you are getting an over volocity.. Could you please tell me if you get the error in Exact stop? I know where there is a problem with CV and I have added some code to check for this but there are times the CV will enter the move a bit to fast..
Brian
Brian,
Off thread but while your here .....
check out the COMPLEX THREADING WIZARD post...
http://www.machsupport.com/forum/index.php/topic,13498.0.html
modified / added link
Hi Brian, thanks for joining in.
If you'll look at the top of the Gcode from my first post here, you'll see the G64, changed that and ran again with G61. the exact same behavior. I'll tell you more than that:
The behavior is 100% repeatable. no matter what g64/1, the only thing that matters is the lookahead value. the machine starts the move, gets to full speed, and somewhere along the way starts loosing steps. if I linger with the E-Stop, it even causes my Geckos 203V light up the error led.
About the over velocity - only happened on version 032, I now run version 029, and get none of the over velocity.
What say you? can it be fixed? I have examples I promised to deliver during next week (mdf doors), Should I delay them?
One more thing that may help: in my configuration, running on 500 lookahead will cause loosing steps on the first jog to the work. this is about 1.4 meters jog to the G59.
Thanks in advance, any help appreciated,
Omri.
Another thing worth mentioning is that feeding the commands one by one on the MDI screen (second screen) causes no trouble at all. The moves are performed without a problem.
I would like to have your XML to test. You can upload it here in a zip file
This is definitely not my latest, but the only things changed are the CV on curves, and the lookahead (almost sure, I'll be able to get the real file only in a few hours)
My latest file attached. Thanks again.
