Mach Discussion => General Mach Discussion => Topic started by: jchal3 on December 22, 2009, 06:33:34 AM
Title: New system set-up help
Post by: jchal3 on December 22, 2009, 06:33:34 AM
Hello,
I am putting together a new mach3 system for a cnc router.  I am confused as to how the stepper driver gets the stepping signals.
First a little background.  The three stepper motors I have are Nema 42 which came off of a piece of packaging machinery.  That machinery was run by an industrial computer.  I have the schematics for the original packing machine.  In the original schematics it shows a +5vdc signal on the step input of the driver, and a -5vdc signal on the direction input of the driver.  This changes throughout the schematic.  I am assuming this is for clockwise and counterclockwise movement.
I am trying to run these drives through my parallel port on my computer, but I don't understand the positive and negative situation.  I was under the impression that if you wanted to step forward, only the step input got the signal, and if you wanted to step back, the direction and step got a signal.
My question is, can I run directly from my parallel port to these inputs, or do I need to go through some other sort of board like the one attached below.  I was under the impression that the board in the attached picture would replace my three drives, not be before them in the circuit.
Any help would be appreciated.
Title: Re: New system set-up help
Post by: Hood on December 22, 2009, 08:54:49 AM
Sounds like your drives may only be capable of using CW/CCW signals, if thats the case then possibly you could use MaxNC mode but I dont know enough about it so best do a search of the forum or look on the ftp site as I think it has pinouts.
Post by: Tweakie.CNC on December 22, 2009, 09:26:25 AM
 The PC parallel port is not capable (without additional circuitry) of providing a -5 Volt signal it is just +5 Volts or 0 Volts (within a certain tolerance).
 The board you have shown in the picture will replace your drivers and will be easy to hook up. Additionally it has the spindle relay and I think, would be ideal for a router.
Hope this helps,
Post by: jchal3 on December 22, 2009, 10:18:39 AM
Tweakie,
So if I were to buy this board, I would connect to it with the PC's parallel port. Then from that to the motors.  All of the signal circuits will be internal basically...right?  Do I need a seperate power supply for the board, and one for the motors, or how does that normally work.
Please keep in mind that my motors are Nema 42's and will be drawing a max of 65dc and 7.9amps per motor.
Post by: Hood on December 22, 2009, 10:34:30 AM
I dont know what the above board is but doesnt look it will be fit for these motors but looks can be deceptive, do you have the specs?
Have a look at the Chinese drives at Kelinginc.net  or the Geckos at geckodrive.com.
Post by: jchal3 on December 22, 2009, 10:43:20 AM
Hood,
I hadn't actually looked at the specs on it yet.  i just didn't know if I needed that and my drivers, or just that card by itself.  I am having trouble with my current drivers (they are so old they are not supported by the manufacturer, and I can't get any info on them.)  I will probably just buy one of the above drivers, but I will spec out the voltage and current before hand.
Post by: Hood on December 22, 2009, 10:50:22 AM
Ok if your old drives or no use then you will just need new ones, my preference is for separate drives for each axis and a breakout board to connect them all together and then the breakout connects to the parallel port. You dont really need a breakout board but it will be easier to connect things and it will probably make connection safer as well.
 The reason separate drives would be best is if one drive dies you dont have to replace the whole board, might be a bit more expensive in the first place but will likely work out a lot cheaper in the long run. Having said that I dont know of any combo drives like the one above that would be capable of powering your motors anyway, even Geckos and Leadshine (Chinese drives, Keling etc) will be at their max.
Post by: stirling on December 22, 2009, 11:02:13 AM
The specs on ebay for this board say its 12-36Vdc and Max 3.5A / motor so I'm thinking it's not for your motors. Also there's an intriguing comment on the ad.
"*Important note: If you use  power supply 12-36V with lower current than 8 amps such as 12-36V 4 amps, the driver may be broken !"
Huh?
Ian
Post by: Tweakie.CNC on December 22, 2009, 11:47:28 AM
As has already been said - This board is no good for 7.9 Amp motors.
Incidentally they sound a bit mighty for a router - they would drive Hood's Beaver.  ;D
Post by: Hood on December 22, 2009, 11:49:41 AM
Now stop getting personal ;D
Post by: jchal3 on December 22, 2009, 12:02:12 PM
sterling,
So I have to make sure I get the 8 amps no matter what voltage I use?  With the maximum voltage being 65vdc.
Post by: stirling on December 22, 2009, 12:08:21 PM
Tweakies last comment (not the bit about the beaver - arf) is well worth thinking about. Art and Marris both (escapes me where and when) discussed at some length the specific problems of big motors. Big is not allways better (specially in a beaver).
specifically to your question - I have no idea. Their comment makes no sense to me at all.
Ian
Post by: Tweakie.CNC on December 22, 2009, 12:35:54 PM
Jchal,
Just for a reference point what are the planned dimensions for your new build machine ?.
Post by: jchal3 on December 22, 2009, 01:02:48 PM
TWEAKIE,
I'm hoping to go 4ft. by 4ft.  I know the motors are overkill, but them and the drivers were freebies.
Post by: Sam on December 22, 2009, 05:16:17 PM
Hard to throw something free away, ain't it!
Post by: Hood on December 22, 2009, 05:22:32 PM
I have one of these drives on the second spindle of the coil winder I made http://www.arceurotrade.co.uk/Catalogue/Stepper-Motors/Stepper-Drivers they are 80v max 9 amp max so should work fine for your motors.
