Mach Discussion => FAQs => Topic started by: yogi on December 19, 2009, 05:12:58 AM
Hi hope someone can help.
this is a new error that we are experiencing with Mach 3.
It never used to do this.
What happens is that if you load a Toolpath. It will cut about 200 lines and then skip ~1000 lines.
There is no fault with the toolpath loaded, you can see that the parts skipped is loaded and available if you step through it.
How can this be fixed?
We are running Version 2.0.003.
I have attached one of the toolpath we are trying to use
