Hmm, Having trouble with this. I just hooked up the 10V to the C11G because I measured the draw at @ 14mA so figured it would not hurt anything. It sort-of works, but it takes a long time for the speed to stabilize, and it seems to be super non-linear. Also, it seems to have different speeds depending on if you are increasing S or decreasing it. IN other words if you type in 50, then 100, then 150, etc you get different results than if you go backward from say 500 to 450, to 400 etc.
I have it set so that 8V is the maximum and this does not seem to saturate the F-V converter.
Suggestions?
Dustin
I'm using CNC4PC C11 rev. 9.3 and I just can't get it deliver more than 9.3V from the 0-10V analog output. I get the 9.3V at S20500 while the max is S24000. If I go over 20500 rpm the voltage will drop again to somewhere around 8.5V. My VFD does not deliver 12V so I'm using an external DC/DC converter which delivers 11.88V from the 5V supply, a 0.1% error I guess shouldn't make that much difference, or? Any ideas what to try next. (Unless - being sarcastic - the card rev # 9.3 means that you need to stick with 9.3) :) :(
/Risto
What voltage are you providing to it? The spindle control will NOT be able to provide the full input voltage. So, if you want 10V out, you'll have to provide it with 11-12V in.
One other thing I cannot figure out is the pulse width setting, can you not change the value independently? I had to set it to 10us on the spindle to get the voltage high enough, but I would like to have the servo pulses be 5us. Is there any way to do that? Now it just changes all the values at the same time.
Dustin
Personally, I'd take a PWM spindle control interface over a Step/Dir charge pump any day. Peter Homanns DC03 works flawlessly, and is VERY accurate and linear. I can typically set VFD frequency to with 0.5Hz or better.
Me too. :)
1- The VFD I am using ( a 15HP GS3 from automation direct) has an analog output supply of 10V at 20mA max. The C11G has a required input of 12V @50mA. Do I really need another isolated power supply? I feel like I have about enough in that control panel... 24VDC, 24VAC, 12VDC for the drives, 60VDC for the servos, and on and on.....
