Mach Discussion => General Mach Discussion => Topic started by: JohnHaine on November 30, 2009, 05:30:20 PM
Hi, I wonder if I could tap the collective wisdom on a problem I'm having? I've got the mechanical conversion of my Super-7 done and built the electronics and everything seems to work fine in "manual" - it jogs properly and accurately and all seems OK.
Then I started to try actual CNC turning and have met a problem. I started with a piece of 1" bar, to turn down to a shoulder a 10mm long spigot 20mm diameter. I set the tool origin to Z=0 at the end face of the bar; and X=25.4 diameter on the diameter. I set the rough cutting to 0.25mm depth and 15 mm speed; and the finish cut to 0.1mm and 5mm; clearance was set to 1mm.
When I set the spindle running and fire off the cycle, it takes the first cut fine; but when it gets to the end it feeds the tool firmly INTO the work and quickly returns the Z axis taking off some very thick swarf in the process! At that point I pressed the estop in a panic. It has happened a couple of times...
Could anyone give any pointers as to what I'm doing wrong please?
I should say that I've been really impressed by loading and setting up Mach3, it's a great piece of work and I can see that I'll be spending a lot of time re-learning the lathe!
Thanks, John.
Where are you getting the code from?
Ah, sorry, I'm using the wizard - radiused shoulder (but with radius = 0).
John.
Can you attach the code you get, may be a problem withthe wizard.
You say "it has happened a couple of times".
Does that mean that some times it's OK?
If you run without a part or just look at the graphics are things OK after the move into the part?
John,
I would check your axis for backlash. When it's done with the finish pass it should pull back that 1mm , clear the stock, and then move back in Z completely clear of the stock. Additionaly you may wnat to make sure your work is rigid, since there could be some spring. Post the code , but, i don't think it is the code, but rather your lathe.
Thanks for all the input. Just for the record, tonight I did some testing with a DTI instead of the tool and a 3/4 test bar in the taper socket, so I could monitor the actual moves. There was no sign of the problem, everything went as expected, actual tool moves made exactly as the on-screen monitor showed. No sign of rigidity problems (this is a S7, and it cuts perfectly normally under manual control), backlash within expected limits.
This test was done with the spindle stationary; then I tried again with the motor running but clutch disengaged; and again with spindle rotating - everything still as expected.
I decided to try again with a tool and cutting a bit of stock (not my test bar!). One thing I did was to change from "Tool 0" to tool 1 - don't know if that's significant. Anyway, this time it worked exactly as expected, no sign of the previous problem. What was going on I don't know, but it seems to be fixed!
Thanks for the suggestions, sorry this was maybe a red herring, but they made me go back and check everything so for me it was useful.
So a milestone (for me) - lathe/computer combo has made its first unaided successful cut!
John.
Could have been that you had Tool Zero chosen, not sure what that would do as I have never tried LOL
Good to hear you have it cutting now :)
