General CNC Chat => Show"N"Tell ( What you have made with your CNC machine.) => Topic started by: ART on November 10, 2009, 09:57:39 AM
Hi Guys:
I figured someone might like to see my clock.. soemthing I decided to try and ended up spending 3 weeks obsessing on. :-)
Art
Hello Art
Real nice clock
Marcel Beaudry
very nice Art, Did you start with plans for something like this? Looks really complicated.
Hi Guys:
Its not that hard. I kinda did it on the fly just making the gears and attaching them to a poplar board.
Theres a program called involute that can instanly give you cnc code for the gears, so I picked the number of
teeth I needed, and made up a bunch of gears. Then I attached them to a baord, maked the holes, copied that
to cad and designed a bunch of cutouts on the board.
Designing the pallet for the escape wheel was the only part you need to study up on..
Anyone wants the Gcode I have most of it laying around for all the gears and such..
Art
I really like it. Looks great. 8)
Is it a little after 3 o'clock?
Art,
I am glad you're having fun. The clock looks real good.
Is it a weight hanging down there that triggers the clock?
Still looks complicated to me calculating all the gear ratios required ;)
Thanks for showing,
Daniel
Hi Guys:
Yup, 3:16 or so..
Theres a weight box hanging down below, that weight is strung to a wooden pulley on a wooden ratchet.
Gears are pretty easy , deadbeat gear is a 30 tooth wheel with an 8 tooth pinion. That turns a 64 tooth with an 8 tooth pinion, and that turns a 60 tooth. ( that will now rotate once per minute with a 43" pendulum , so thats the minute hand). On that shaft an 8 tooth drives a 24 tooth wheel with a 10 tooth pinion that driver a 30 tooth hour hand shaft.
Thats about all you need really. Theres lots of web pages out there to show how escapements work..
Later.
Art
ART,
About time you get to play around some. It is rather unique and i like it.
Don't know much about clock's so only one question.
Where is the coo-coo ? In Lithuiania we mount then on the counter weight. ;)
Rich:
Originally, my plan was to have an eyeball that flicked back and forth as my "cuckoo" , this thing taught me something about friction though. LOL
Since the weight is hung on the minute shaft, by the time we get to the escape wheel you have 1/3600 of the original torque. A 10 pound weight then pushes about
an ounce or so on the end teeth to keep the pendulum going..
Yeah, it was fun to try out the new workshop on something like a clock.. looks so damn simple but has lots to bite you with..
Im thinking up a new challenge for the next project. :)
Art
Really nice clock Art. Does it have a satisfying tick ?.
An annoyingly loud one actually.. :) , but I only run it an hour or two at a time, more of a kinetic art piece than a timekeeper..
Art
Art,
Will it work on Central standard time ? ;D ;D ;D
Ed
Hehe...that's funny Ed. Nice clock Art, I've never seen one like it before.
