Mach Discussion => General Mach Discussion => Topic started by: krymis on November 04, 2009, 03:36:59 PM
Can someone explain to me the tool height and touch probe thing. I am currently using a Littlemachine shop manual edge finder for x and y. For Z i am using zigzag paper. once they all are zeroed i zero my DRO. am i doing it wrong? will this touch probe thing make it easier to do the same thing. I was talking to another guy and he said to use an electronic edge finder without the battery. With out the battery the tip is isolated and can be used as a probe i guess. I guess i do not really understand the point or the operation enough to event field the questions i want answered.
There are quite a few explanations for use of the touch plate here on the forum but, if you wish, you can see how I set up my tool positioning here:-
http://www.cooperman.talktalk.net/files/17.htm
Hope this helps.
