Mach Discussion => General Mach Discussion => Topic started by: woodguy7777 on October 10, 2009, 12:20:08 PM
> I am new to mach3. downloaded the trial program trying to run a few files
that i made using vcarvepro i made a few squares run them and everything seem
to go ok
> i then made a file with a circle and also some with diff shapes.
> those dont run.
> when i import these files into mach3 the files is highlighted about the center
on the list of code.
> hit cycle start nothing moves.
> any help?
> paul
the file i am using is of a 18 inch circle with 23 lines of code
when i load the file the 8 line is highlighted when i use the rewind
button and go to the top [start of code] file would run until it reach the eight
line and stop.
looking at the table display mode this show a straight line been drawn no part
of a circle.
I have tried a number of circles and they are all the same.
but never a problem with squares i made a file with 20 squares and that worked.
i made a file with a circle and a square together that dont work.
thanks paul
Try changing the IJ mode in general config.
