Mach Discussion => General Mach Discussion => Topic started by: radioactive on October 07, 2009, 05:01:03 AM
I never set up the homing on my mill since once I mounted a vice on the table, it would crash the back of the vise into the machine if it tried to home it. Been manually setting it up ever time I turn on the machine. That's getting old and I'm doing alot of the same parts over and over.
Can I change the setup so when I try to home the machine it sends the table towards me (in the negative Y direction)? X and Z homing isn't a problem.
Or do I need to modify my limit switch?
Config menu then Homing and limits and either check or uncheck the Reverse option.
