Mach Discussion => General Mach Discussion => Topic started by: hightechkey on September 06, 2009, 09:07:58 AM
Title: Can I use Suqiang SN2000 Serial Servo motor drive with Mach3
Post by: hightechkey on September 06, 2009, 09:07:58 AM
Hello,
          I have two pairs of Suqiang SN2000 Serial Servo motor drive and motor. I have a plan to change my conventional lathe machine to CNC machine with this driver and motor. I want to change this with Mach3 cnc control software. So, I want to know that can I use this drive and Mach3 software? Mach3 Software generates the "Step" and "Direction" signal to drive the servo motor. So, is Suqiang Drive accpet "Step" and "Driection" signal? I have no experience about servo
drive. This is my first experience. Please inform me can I use or not this drive with Mach3 software. Please tell me which pins that I connect for step and direction if it is possible. I am looking forward
your reply. Thank.....
This drive link is:
http://www.sqsk.cn/en/productshow.asp-showid=73.html
The following link is for this SERVO DRIVER-SN2000 manual.
http://www.sqsk.cn/en/SERVO%20DRIVER-SN2000.pdf
Please tell me connection diagram between Parallel port and drive if you are OK. I hope someone will help me.
High Tech Key
Reply Wit
Title: Re: Can I use Suqiang SN2000 Serial Servo motor drive with Mach3
Post by: Hood on September 06, 2009, 09:54:41 AM
Yes they take Plus/Sign which is another name for Step/Direction. I dont have time to go through the manual at the moment but it is showing it takes differential signals, it may be happy with single ended signals that the parallel port will put out but if not a line driver would do that job and is cheap enough.
Post by: hightechkey on September 06, 2009, 10:12:12 AM
Dear Hood
         Thank you very much for your reply. Do you mean Plus for step and Sign for direction. Am I only connect this pin with parallel port pin using breakout board.  I am very glad to hear this. Thank again....
High Tech Key
Post by: Hood on September 06, 2009, 06:11:10 PM
Yes thats correct, still not had a chance to look right through the manual but it seems from first glance that you can set the parameter PA 14  to 1 and that will allow you to use single ended inputs.
 So looks like Step pin to Pin 18, Dir to Pin 19 on CN1
Post by: hightechkey on September 07, 2009, 09:13:19 AM
Dear Hood
        Thank for your reply. I don't understand to set PA 14 to 1 for single ended input. I have no experience with servo drive. Please explain more details. I see 2 pins for Plus and 2 Pins for sign. Which pin can I use? Can I use only 18 and 19 pin for step and direction as you reply. Thank...
High Tech Key
Post by: Hood on September 07, 2009, 09:28:11 AM
Differential signals have a positive and at the same time an exact opposite negative pulse. It helps to combat the effects  of electrical  noise.
The parallel port will only put out a positive  pulse so that is what is called single ended, you can get a line driver which will output an opposite to the pulse that is input to it as well as passing the original thus making the signal differential. It is preferable to do that as noise is less of a problem but probably wont be needed.
PA 14  (Parameter 14) is a parameter in the drive, you can set it to 1, 2 or 3.  1 seems to be to set the drive so that it accepts single ended signals.
Had a glance through some of the other parts of the manual and there is much more info about the pulse/Sign  signals later on so best to read all that first before you wire anything up as there was mention of resistors needed, the value of which is dependant on your voltage and also whether its single ended or differential.
Post by: hightechkey on September 07, 2009, 09:55:40 AM
Thank you for your explaining. Now, I understand a lot. I will read manual carefully and wiring the drive. I will ask more questions if I see some difficulty.
High Tech Key
Post by: hightechkey on September 14, 2009, 12:01:53 PM
Dear Hood
        I have been read Suqiang SN 2000 manual book. Now, I draw the connection diagram for one axis servo system with Mach3 control. I upload this drawing and please advice me it may be work or not. I hope it can be work. I use EL817 photocoupler for opto isolation between parallel port and servo driver. I read from manual that this drive can input single phase or three phase 220 VAC. So, I input single phase 220VAC.  I want to know about my input power is single phase and servo motor using U, V, W 3 phases power. Is it OK or not? Please explain me about this power system.
        Will I need Alarm Clear (Pin 9 in CN1) and Deviation Clear (Pin 23 in CN1)? I think it is not so important. I also want to know about output pins from Servo Drive (Servo Ready, Servo Alarm, Position Complete, etc). Do I need to use with mach3 system for output pins from servo driver. How can I connect with mach3 if I want to use this output pins? I hope you can advice me about this system. Thank a lot...
High Tech Key
Post by: Hood on September 14, 2009, 04:33:24 PM
I have not looked at the manual again but the wiring looks like it will be fine.
 Couple of things, first the enable would be better connected to Mach. Because it is 12v you will need to use a relay with a 5v coil and use Mach to switch the relay. Mach has several Enable outputs but I just use one for all drives.
Alarm Clear can either be connected to an output from mach via a relay or you could just fit a switch on your panel to operate it independent of Mach.
Servo Alarm would be best connected to Mach. To do this you would have a relay operated from each drives alarm signal and the contacts of these relays in series so that only one input to Mach is needed. You then set this up as Input1 and enable the Input 1 option on General config page in MACH. That will mean if any of your drives fault Mach will stop motion and also disable the other drives.
Post by: hightechkey on September 15, 2009, 10:28:38 AM
Dear Hood,
      Thank for your reply. I want to know about input pin for Servo Alarm. I enable Input #1 at Port and Pin. Then I use port1 pin13 for input pin. I test this pin with external input button. But it is not work anything. I test this button for limit switch and estop switch input. This perfectly work. How can I do for using servo alarm input? I think I will do some setting for Input #1. Please advice me.
      I also want to know about OEM Trig for input signals. I enable and set the pin, port number for OEM Trig. Then I go to System Hotkey and set for OEM code. Where can I find OEM code for cycle start, stop, estop and etc. Thank a lot....
High Tech Key
Post by: Hood on September 15, 2009, 11:23:42 AM
For the Alarm signal you need to go into Config menu then General Config  and down at the lower left you will see the option for Programme Safety Lockout.
There is a list of OEM codes  in the thread at the top of the forum.
Post by: hightechkey on September 16, 2009, 04:46:03 AM
Dear Sir
        Now I finish testing for input1. It is work. Thank..... I have another question. I want to move my axis for Reference All Home function at the start of Mach3 program. I found some startup function for Gcode in General Config. I insert G30 for return home. It is working. But I need All Reference Home at the start of mach3. How can I do for this. I think you understand what I mean. My English skill is a little bad.
High Tech Key
Post by: Hood on September 16, 2009, 04:52:51 AM
Open notepad and type
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
Then save it as m101.m1s in the macro folder of the profile you use, for example if you use the default Mach3Mill profile you save to C:\Mach3\Macros\Mach3Mill
Then put m101 in the initialisation string.
You  dont have to save it as m101, you can save it as any m number you like as long as its above 100 and it is not being used already by another custom macro.
Post by: hightechkey on February 25, 2010, 11:29:24 AM
Dear Hood
I finished my cnc conversion with this motor drive and motor(SN 2000 serial servo). Thank you so much for your valuable advice.
But I have some problem with this machine. My machine going home at the start of mach3. My motor drive often got error Y or X homming sequence at the start of my machine. The error code is Error3. I turn off the drive that show error and turn on again. After that everything is ok. The drive error often get at the start of my machine. I think my driver should be change some parameters. I try to change some parameter reference from the manual book. But It didn't work. I don't know how to solve this problem. Please help and advice me. Thank you.
High Tech Key
Post by: Hood on February 25, 2010, 04:02:07 PM
According to the manual Error 3 is over current, check that you do not have the acceleration set too high or that your motors are not too small for the weight you are trying to move. Also check all of the wiring connections are secure.
