Mach Discussion => General Mach Discussion => Topic started by: morgan on August 31, 2009, 09:37:35 PM
I keep getting an error that says " Radius to end of arc differs from radius to start of line "
I'm using vectrics Aspire and Vectrics pro 6 and both get the same error is there a setting in Mach 2/3 that might have got changed ?
IJ mode in general config.
thanks ger21 I'll give it a try tomorrow
Ger21 thanks I changed the setting of the iJ mode and it works great your a life saver
thanks again
