Mach Discussion => General Mach Discussion => Topic started by: Chip on August 25, 2009, 06:48:45 PM
Hi, Jim
On My Compact 5 Lathe the index disk is about 4.5" in Dia. with about a 5/8 " slot to allow Mach to have time to see the opto Puls.
You may be able to use your Index pulse output as it is and add a IC555 Timer to reset with a adjustable time delay, R1 Var. resistor.
Just A Thought Hear, Chip
Edit: the resistor value is 1K and cap is 0.1 uf. This seemed to be the best values.
pules widening
