Mach Discussion => General Mach Discussion => Topic started by: DanB on August 20, 2009, 10:37:44 PM
I'm currently using CandCNC's screenset for plasma cutting and recently i needed to use the option Feedrate override and it wont work the percentage changes and the FRO number changed but the Unit/Min stayed the same and the cutting didnt go any faster..
any suggestion on how to enable it
Hi, Dan
What version of mach3 are you using. It's under, Help, About ?.
Chip
I think you probably have the "No FRO on Que" box checked in the General Configuration page.
HTH,
Sid
R3.042.024
the no FRO on Que was unchecked and i did try check it and it didnt change anything..
its now back unchecked...
Can you attach an example of the code and also your xml please.
here are the files.. any other files would you need?
Thanks for your help
It seems to be working fine here but I am just using the standard Plasma screen as I dont have the MP1000-THC4a.set that you are using.
Just as a test load the standard sceen and see if it works.
okay ill give that a try then will let u all know in 15 min :)
i just changed the screenset and then it worked then switched it back and it still works.. pretty wierd but im happy it works now..
Weird but as long as it works thats the main thing :)
Hi, Dan
Tried your xml & G code files with ver .024 and ver .029, I did get a better result with ver .029's override, It got an increase with both ver's though.
Thing's sometimes get screwy now and then, Glad it's working now.
Chip
