Mach Discussion => General Mach Discussion => Topic started by: Steve_B on August 05, 2009, 06:57:28 PM
I just read in section 4.4.1 of the latest Mach3 documentation & found a little over half way down the page steppers need to be driven by a Chopped Micro Stepping controller. What is that ??? I have a 1995 gantry that has run well with the Oriental 5 Phase steppers & drivers. I just need better motion system software. There is no resistance load on the gantry just the weight of the cross member. Anyway we will be replacing a 486 PC to use Mach3 for our motion. Could I have problems with old electronics? Will the drivers know the difference?
Modern stepper motors and drivers often give smoother performance compared to older ones. If you are happy with it, as it is now, then you should be fine :)
When I watch YOUTUBE videos the Mach run machines are whining very loud. Our machine is a little loud once in a while but nothing like the ones onYOUTUBE. Is the whining due to lower cost drivers & motors. What are good steppers & drivers for Nema 34 size motors? Medium light duty.
I have Gecko G202 on the Bridgeport and the Chinese drives available in the UK from Arc Euro on the coil winder. The Geckos are smaller and I must admit I prefer them although to be honest there doesnt seem to be much difference in performance.
A comment on sound:
With the additional mass of the 4th axis to move around, my 'X" axis started loosing steps occasionally, so I am planning to replace it with a servo motor. Until I decide which motor I want as a permanent replacement, I replaced the 425 oz-in NEMA23 (parallel wired) with a 640 oz-in NEMA34 (series wired) stepper that I had left over from my 4th axis project. Gecko 203V drive @ 72V.
http://www.kelinginc.net/SMotorstock.html (http://www.kelinginc.net/SMotorstock.html)
While I have not done any performance testing or run any parts yet, I can tell you that the difference in sound is extreme.
The NEMA23 was a screamer and the NEMA34 is almost as quiet as a servo. So my little Fankenmill currently has a NEMA34 on the 'X" and the NEMA23 on the 'Y'. With a program running, all you hear is the little 23 motor screaming away.
