Mach Discussion => Mach Screens => Finished Screens => Topic started by: giordano on August 01, 2009, 12:41:26 PM
Hello to all. I can not change the files. Set in the Addons folder. It is not possible or am I wrong? Regards, Giordano Cantori
I do not understand your question, but one problem you may be seeing is that Screen4 does not get the path correct, so it does not display the bitmaps that are in your bitmap folder.
The only way around this is to move the .set file and all its bitmaps to the Mach3 folder and to Mach3\bitmaps
I have asked Brian about this and he has tried to fix it but for some reason it is to deep into the Screen4 code to fix
Hello Ron. I created a new interface for Mach3, in Italian and English. I noticed that the wizard screens are a bit messy and I would like to modify them with the same style as the main interface. Regards, Giordano.
