G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: Maxwell Robach on July 24, 2009, 11:55:11 AM
:11 (FINALDESIGN.TAP)
/G28 U0. W0.
M01
N01 ( T01 )
G28 U0.
T0101
G0 X150. Z200.
G97 S1000 M3
G0 X4.157 Z1.079 M8
(TR-CONTOUR-T1A - TURN)
G99 G97
G0 X4.158 Z1.078
X4.078
G1 X3.92 F0.01
Z-2.643
X3.998 Z-2.808
X4. Z-2.811
X4.158
G0 X4.172
Z1.078
X3.84
G1 Z-2.498
X3.92 Z-2.643
X3.936 Z-2.635
G0 Z1.078
X3.76
G1 Z-2.369
X3.84 Z-2.498
X3.856 Z-2.49
G0 Z1.078
X3.68
G1 Z-2.253
X3.76 Z-2.369
X3.776 Z-2.362
G0 Z1.078
X3.6
G1 Z-2.146
X3.68 Z-2.253
X3.696 Z-2.245
G0 Z1.078
X3.52
G1 Z-2.046
X3.6 Z-2.145
X3.616 Z-2.138
G0 Z1.078
X3.44
G1 Z-1.953
X3.52 Z-2.046
X3.536 Z-2.039
G0 Z1.078
X3.36
G1 Z-1.866
X3.44 Z-1.954
X3.456 Z-1.946
G0 Z1.078
X3.28
G1 Z-1.783
X3.36 Z-1.866
X3.376 Z-1.858
G0 Z1.078
X3.2
G1 Z-1.704
X3.28 Z-1.783
X3.296 Z-1.775
G0 Z1.078
X3.12
G1 Z-1.629
X3.2 Z-1.704
X3.216 Z-1.696
G0 Z1.078
X3.04
G1 Z-1.557
X3.12 Z-1.629
X3.136 Z-1.621
G0 Z1.078
X2.96
G1 Z-1.488
X3.04 Z-1.557
X3.056 Z-1.549
G0 Z1.078
X2.88
G1 Z-1.422
X2.96 Z-1.488
X2.976 Z-1.48
G0 Z1.078
X2.8
G1 Z-1.358
X2.88 Z-1.422
X2.896 Z-1.414
G0 Z1.078
X2.72
G1 Z-1.297
X2.8 Z-1.358
X2.816 Z-1.351
G0 Z1.078
X2.64
G1 Z-1.238
X2.72 Z-1.297
X2.736 Z-1.289
G0 Z1.078
X2.56
G1 Z-1.181
X2.64 Z-1.238
X2.656 Z-1.23
G0 Z1.078
X2.48
G1 Z-1.125
X2.56 Z-1.18
X2.576 Z-1.173
G0 Z1.078
X2.4
G1 Z-1.072
X2.48 Z-1.126
X2.496 Z-1.118
G0 Z1.078
X2.32
G1 Z-1.02
X2.4 Z-1.072
X2.416 Z-1.064
G0 Z1.078
X2.24
G1 Z-0.969
X2.32 Z-1.019
X2.336 Z-1.012
G0 Z1.078
X2.16
G1 Z-0.92
X2.24 Z-0.969
X2.256 Z-0.962
G0 Z1.078
X2.08
G1 Z-0.873
X2.16 Z-0.921
X2.176 Z-0.913
G0 Z1.078
X2.
G1 Z-0.827
X2.08 Z-0.873
X2.096 Z-0.865
G0 Z1.078
X1.92
G1 Z-0.781
X2. Z-0.826
X2.016 Z-0.819
G0 Z1.078
X1.84
G1 Z-0.738
X1.92 Z-0.782
X1.936 Z-0.774
G0 Z1.078
X1.76
G1 Z-0.695
X1.84 Z-0.738
X1.856 Z-0.73
G0 Z1.078
X1.68
G1 Z-0.653
X1.76 Z-0.695
X1.776 Z-0.687
G0 Z1.078
X1.6
G1 Z-0.613
X1.68 Z-0.653
X1.696 Z-0.646
G0 Z1.078
X1.52
G1 Z-0.574
X1.6 Z-0.613
X1.616 Z-0.605
G0 Z1.078
X1.44
G1 Z-0.535
X1.52 Z-0.573
X1.536 Z-0.566
G0 Z1.078
X1.36
G1 Z-0.497
X1.44 Z-0.535
X1.456 Z-0.527
G0 Z1.078
X1.28
G1 Z-0.461
X1.36 Z-0.498
X1.376 Z-0.49
G0 Z1.078
X1.2
G1 Z-0.425
X1.28 Z-0.461
X1.296 Z-0.453
G0 Z1.078
X1.12
G1 Z-0.39
X1.2 Z-0.425
X1.216 Z-0.417
G0 Z1.078
X1.04
G1 Z-0.356
X1.12 Z-0.39
X1.136 Z-0.382
G0 Z1.078
X0.96
G1 Z-0.323
X1.04 Z-0.356
X1.056 Z-0.348
G0 Z1.078
X0.88
G1 Z-0.29
X0.96 Z-0.322
X0.976 Z-0.315
G0 Z1.078
X0.8
G1 Z-0.259
X0.88 Z-0.291
X0.896 Z-0.283
G0 Z1.078
X0.72
G1 Z-0.228
X0.8 Z-0.259
X0.816 Z-0.251
G0 Z1.078
X0.64
G1 Z-0.197
X0.72 Z-0.227
X0.736 Z-0.22
G0 Z1.078
X0.56
G1 Z-0.168
X0.64 Z-0.198
X0.656 Z-0.19
G0 Z1.078
X0.48
G1 Z-0.139
X0.56 Z-0.168
X0.576 Z-0.16
G0 Z1.078
X0.4
G1 Z-0.111
X0.48 Z-0.139
X0.496 Z-0.131
G0 Z1.078
X0.32
G1 Z-0.083
X0.4 Z-0.111
X0.416 Z-0.103
G0 Z1.078
X0.24
G1 Z-0.056
X0.32 Z-0.083
X0.336 Z-0.075
G0 Z1.078
X0.16
G1 Z-0.03
X0.24 Z-0.056
X0.256 Z-0.049
G0 Z1.078
X0.08
G1 Z-0.004
X0.16 Z-0.03
X0.176 Z-0.022
G0 Z1.078
X0.
G1 Z0.021
X0.05 Z0.005
X0.08 Z-0.004
X0.096 Z0.003
G0 Z0.968
G1 X-0.064
Z0.042
X0. Z0.021
X0.016 Z0.029
G99 G97
G1 X0.09 Z0.086 F0.05
Z0.113
X-0.028
Z-0.005
G3 X3.999 Z-3.026 R4.439
G1 Z-3.732
X4.222
G0 Z0.079
G0 X190. Z200.
M30
thats the G-Code generated, i get the error "Bad Character usedLine 1" i've tried to change several things any help is appreciated.
Lathe- CJ9526
Hookup- SyiL
Fairly new to this trying to make a nose cone for a submarine we designed in SolidCam.
anyone??...
Mach will see a few errors in this file - I suggest you comment them out.
For exmple change
to
(:11 FINALDESIGN.TAP)
Others Gcode lines Mach doesn't like are
G99 G97 which occurs twice in the code - change them to (G99 G97) . That is comment them out by putting brackets either side of the Gcode.
I also see from the code that the tool starts and ends a long way away from the cutting area - G0 X150 Z200 - I suggest you change them to G0 X5 Z5 - you'll need to do this twice.
You have also probably used the Fanuc post processor in SolidCam as there isn't one that I'm aware of for Mach3 so you'll have to manually edit the Gcode everytime.
Hope this helps.
Jim
I have also noticed that your feed rate at F0.01 is very slow I suggest you change this to someting like F150 - assuming you are woking in mm rather than inches
I have
Hi, Maxwell
There are some Issues in the post your using, Post the dxf if you can.
Chip
Hi, Maxwell
Was able to resolve it a bit more, You need to check if they have a post for Mach3.
Hears another pic and a G code for this.
Chip
Hello All,
I ran into the same fault codes yesterday.
I managed to generate a G-code with Solidcam after many, many tries.
First I had to find a solution for two fault messages from Solidcam itself. Thanks to CNCzone.com.
As a first solution I deleted the offending lines and Mach3 produced my simple design on my Emco Compact5 CNC lathe.
That worked.
I also encountered the long distance that the tools is set . G0 x150 z200.
Why Sc does this I do not know.
Also the Feed is set at F0.3 , way too slow and I changed that to F100. Exactly fine for my little lathe.
So, there is some more fiddling to be done with Solidcam.
Thanks for all the info.
Jos
Holland
mraven.com
